Discussion topic: WiFi intermittent
This message was authored by: Sid12
WiFi intermittent
Hello, my WiFi is having problems staying connected. It will be good for a small amount of time and then shut off. It has been doing this for about a week now. Is there anything you can do to help me out. This is the first time it's happened
Re: WiFi intermittent
@Sid12
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
