Discussion topic: WiFi inconsistencies
This message was authored by: EmJudge
WiFi has been dropping in and out for 3 days
Re: WiFi inconsistencies
@EmJudge
There’s a possibility the current heavy rainfall may be causing some broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Avatar for EmJudge
Hi Daniel thank you I am aware of the difference - I had used the checker and every time the signal to the house is fine that is why I mentioned WiFi
