2
This discussion topic has been answered Discussion topic: WiFi in house not working
This message was authored by: Sara17
I've tested the wifi and it says it's good however nothing will connect to it. Tv won't download anything and our phones and iPads won't connect
Re: WiFi in house not working
@Sara17
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
@Sara17 Is it the wireless wifi signal or the Broadband Internet, both are different conditions and fault's. See the help below that may give you some idea!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
@Sara17
