6
This discussion topic has been answered Discussion topic: WiFi has stopped working
This message was authored by: Demmi
Hi, my WiFi has stopped working, light 1 is green, light 2 is orange, light 3 is green and light 4 is orange on the WiFi router
Re: WiFi has stopped working
All,
When there are any broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided..
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
This message was authored by: Shawtie
Me too, I have unplugged and re plugged and still the same
This message was authored by: Jembamin82
Mine is the same it went off came back for a short period now has done exactly the same
This message was authored by: Kamarjelin
Same here
All,
This message was authored by: Lucy777
Mine has also stopped working since 9pm last night
@Lucy777
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
