Discussion topic: WiFi has no internet
This message was authored by: Harry_krieger
I have a green power and wifi light on hub but no internet
Re: WiFi has no internet
@Harry_krieger
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
