Discussion topic: WiFi gone off
Message posted on 10 Apr 2026 01:34 PM
WiFi gone off
WiFi just went off orange light in the middle
Message posted on 10 Apr 2026 01:42 PM
Re: WiFi gone off
@Malkin71
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
