Discussion topic: WiFi gone off
Message posted on 01 Oct 2025 12:51 AM
WiFi gone off
Message posted on 01 Oct 2025 05:40 AM
Re: WiFi gone off
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you are still having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
