Discussion topic: WiFi fault
This message was authored by: Purplerain1
WiFi fault
My WiFi is not working. I've turned it off and restarted with no effect
Re: WiFi fault
@Purplerain1
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
