Discussion topic: WiFi failing
Message posted on 30 Oct 2025 04:46 PM
WiFi failing
My WiFi has cut despite it saying in my sky that all is fine with the connections
it is showing green light, no green light, green light, red light
Message posted on 30 Oct 2025 04:53 PM
Re: WiFi failing
@Kate3871
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
