Discussion topic: WiFi extension
This message was authored by: Kimbo21
Message posted on 27 Jul 2026 11:10 AM
WiFi extension
My WiFi is not reaching all of my rooms
Find out more
Message posted on 27 Jul 2026 01:16 PM
Re: WiFi extension
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
