Discussion topic: WiFi extenders
This message was authored by: AshvinPankhan
Message posted on 14 Aug 2026 05:58 PM
WiFi extenders
Pod in my breakfast room shows poor signal and need engineer to come out, this is 5th time I am reporting an issue and not very happy as security of my home is at risk
Find out more
Message posted on 14 Aug 2026 06:20 PM
Re: WiFi extenders
@AshvinPankhan try moving the pid closer to the hub. These unitsxshould be placed roughly halfway between the hub snd where you need the boist. If then you still are nit getting usable Wi`finin every room in your home call Sky as thry will send out an engineer who can issue up to two more pods.
incidentally Sky like every other isp will not gurantee WiFi coverage outside your home to security cameras. If you have reason to be concerned about secirity use of a domestic broadband connection is not going to be sufficent .
