Discussion topic: WiFi drops out
This message was authored by: JACKLANGTON1
WiFi drops out
  • When I switch on my laptop it says WiFi connected but it also says that my router is not connected. I then put in my router password and it is connected But when I try to use WiFi That's the problem
Re: WiFi drops out
@JACKLANGTON1
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
