Discussion topic: WiFi dropping
This message was authored by: Ebie
WiFi dropping
Hi, I’m having ongoing problems with my Sky Broadband connection. The WiFi keeps dropping frequently, even though only around 3 devices are connected to the router. The connection disconnects and reconnects several times, which is affecting normal use.
Could you please check if there are any issues with my line or router and advise what can be done to fix this? If you need any information from my side, I’ll be happy to provide it.
Thank you.
Re: WiFi dropping
@Ebie
As we are customers here we can't check this for you but you can by running this line test to see if it finds any faults:
