Discussion topic: WiFi dropping.
This message was authored by: Steveh91
WiFi dropping.
WiFi dropping in and out mostly out for over a week now. Done all checked and it's says it all good!!!
Re: WiFi dropping.
@Steveh91
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
