Discussion topic: WiFi dropping out
This message was authored by: SammyB871
WiFi dropping out
I have full fibre 300 package with sky max hub. Only joined sky last month having previously been wity virgin. Some areas in the house have a very poor and even no connection at times. Do sky need to provide something to give coverage in every room of the house?
Re: WiFi dropping out
@SammyB871
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
