Discussion topic: WiFi dropping out
Message posted on 28 May 2026 11:21 AM
WiFi dropping out
WiFi constantly dropping out multiple times a day.
Message posted on 28 May 2026 11:35 AM
Re: WiFi dropping out
@Emma8888
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
