Discussion topic: WiFi dropping out
Message posted on 21 May 2026 10:59 AM
WiFi dropping out
Wifi router has four green lights, but keeps dropping out, reset router and works ok, but having to reset at least once a day. When checking connection via sky app on 5g, it states all is connected fine
Message posted on 21 May 2026 11:01 AM
Re: WiFi dropping out
@SimRipley
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
