Discussion topic: WiFi dropping out
This message was authored by: tim-01
Message posted on 08 Jan 2026 09:28 AM
WiFi dropping out
My WiFi is dropping out about every 20minutes when I am on my laptop or phone in an upstairs bedroom. It is as though the router is not able to send a strong enough signal across the house. My android phone defines the signal as fair good and not connected when the devise is not being moved. This is becoming a increasing frustration for all the family.
Find out more
Message posted on 08 Jan 2026 09:49 AM
Re: WiFi dropping out
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
