Discussion topic: WiFi dropping out
This message was authored by: HannahMcDonnell
WiFi dropping out
Hello,
I’m having ongoing issues with my WiFi connection repeatedly dropping out. This happens several times a day and affects all devices connected to the network.
I’ve tried restarting the router and checking the cables, but the problem is still happening. The service has been unreliable for a while now.
Please could you look into this and advise on what can be done to fix the issue? If any tests, settings changes, or equipment replacements are needed, I’d appreciate your guidance.
Thank you for your help.
Re: WiFi dropping out
@HannahMcDonnell
We can't look into anything. You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
@HannahMcDonnell Pay attention to the Hub Lights that @Daniel0210 has advised you on also, not knowing what you have hub wise, how you are connected makes it hard, but the fact you say it all goes can have some bearing on it but ONLY if you have an Ethernet connection on that hub! You say wifi dropping out, if you have a later mobile you may see an ! exclamation mark next to the wifi bars, that will indicate that the wireless wifi is UP but the Internet connection is lost, so becomes a different and separate type issue!
