Discussion topic: WiFi dropping out with no fix
This message was authored by: Aliceeklund
My connection keeps dropping and I have tested, reset and restarted my WiFi as instructed with no fix. Can someone sort this?
Re: WiFi dropping out with no fix
@Aliceeklund
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
