Discussion topic: WiFi dropped out
Message posted on 14 Oct 2025 04:48 PM
WiFi dropped out
Hi,
all of a sudden WiFi dropped connection and there's no internet at the moment. I tried restarting the WiFi set up and also tried to resolve from online help but it still won't work
Message posted on 14 Oct 2025 05:43 PM
Re: WiFi dropped out
@Veronica22
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
