Discussion topic: WiFi down
This message was authored by: pmc72
WiFi down
I have turned off and reset my router, but still have no router
Re: WiFi down
@pmc72
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Avatar for pmc72
Re: WiFi down
Thanks Dan
I went through the usual tests and power cycles. I did have a red LOS light on th ONT, but that has now turned off but the PON light is now flashing green. Power and LAN are solid green....been like that for about 15mins
