Discussion topic: WiFi down
Message posted on 25 Mar 2026 10:06 PM
WiFi down
Message posted on 25 Mar 2026 10:18 PM
Re: WiFi down
We can't fix anything as we are customers who help each other via here.
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
