Discussion topic: WiFi down!!!
This message was authored by: Nik06
WiFi down!!!
WiFi randomly went off. LOS red light on the openreach box!! According to the service checker everything is fine! 🙄
Re: WiFi down!!!
@Nik06
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Also, any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
