2
This discussion topic has been answered Discussion topic: WiFi down
This message was authored by: Donna170174
WiFi down
Completely down in Lancashire
Re: WiFi down
@Donna170174
When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach. Hopefully it'll be back up and running before 7am.
If it's not,even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: WiFi down
@Donna170174
Avatar for Donna170174
Re: WiFi down
Thank you
