Discussion topic: WiFi down
Message posted on 29 Oct 2025 07:00 PM
WiFi down
Wi-Fi currently down
Message posted on 29 Oct 2025 07:13 PM
Re: WiFi down
@Dc1995
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
