Discussion topic: WiFi down
This message was authored by: Jamieevans
WiFi down
My WiFi has gone down
Re: WiFi down
@Jamieevans
A bit early for overnight maintenance.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
