Discussion topic: WiFi down
Message posted on 13 Jan 2025 11:11 AM
WiFi down
My broadband is down despite the Sky checker saying the connection is good. It was previously down for 3 days before Christmas with no explanation from Sky
Message posted on 13 Jan 2025 11:31 AM
Re: WiFi down
@Vacateleft
Message posted on 13 Jan 2025 11:32 AM
Re: WiFi down
Domestic ISPs typically don't provide explanations for individual outages.
You'll need to persist with logging the issue with Sky.
