Discussion topic: WiFi down, solid red light
Message posted on 11 Aug 2024 02:53 PM
I have solid red light on power light. WiFi not working.
Message posted on 11 Aug 2024 04:05 PM
Re: WiFi down, solid red light
@Amycollinson Does the red light stay on if you try in restarting the router?
Message posted on 13 Aug 2024 07:30 AM
Yes turned on and off 4-5 times and still on
Message posted on 13 Aug 2024 07:34 AM - last edited: 13 Aug 2024 07:53 AM
@Amycollinson folow the steps for what type of Sky hub you have in this trouble shooter https://www.sky.com/help/articles/hub-lights-explained-start
A red power light sounds like tge hub is faulty given the number of thunder storms yesterday it is likely a number of hubs have been damaged. Sky will replace these if you call them and have gone through the steps above.
