Discussion topic: WiFi down Royston Herts
Message posted on 28 Jul 2026 11:46 AM
Everything just went off at around 11:25am, I've restarted the router but have an orange light on Voice and no light on Internet. Done a test on the MySky app and it says it's all working but it isn't.
Message posted on 28 Jul 2026 12:10 PM
Re: WiFi down Royston Herts
@SirM6ALot
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
