Discussion topic: WiFi doesn’t work upstairs
This message was authored by: Dg1809
Hi my WiFi doesn't work upstairs
it's fine downstairs where the router is but rubbish upstairs
I don't live in a big house so the distance shouldn't be an issue
I tested the internet speed upstairs and it said it's really slow
This message was authored by: Allnew
Re: WiFi doesn’t work upstairs
Hey what router do u have is it while or black thanks
@Dg1809 it is isn't distancecit is what lies between the hub and your devices upstairs if it includes a couple of brick walls and a floor it is easily explained oldercsmall properties can be just as much an issue as large modern houses. Cut to the chase you need an extender or similar and if you want one supplied by Sky you will havecto buy their https://www.sky.com/help/articles/sky-wifi-max add-on.
