Discussion topic: WiFi disconnects
Message posted on 21 Dec 2025 01:02 PM
WiFi disconnects
Hi all
WiFi signal seems to be dropping a lot we had a new boiler system installed that now monitors throughout the hive hub and this are bringing a lot more issues
Are there any working interference in my area ?
Message posted on 21 Dec 2025 01:09 PM
Re: WiFi disconnects
@Martinha1 Since you introduced the Hive to the system is it the Ethernet connected hive hub that you are using to buffer between both?
It's the hive hub that connect's to the hive controller in the boiler nothing else! Have the son's all working fine, did stick a longer cable between the sky Hub and the Hive hub to make sure that it's signal did reach the boiler fine and that was through a brick wall as boiler was out in the garage, and zero issue's with anything at all!
