Discussion topic: WiFi disconnecting
Message posted on 31 Aug 2026 10:09 PM
WiFi disconnecting
My WiFi keeps disconnecting every couple minutes in past few hours and also it became weaker in past couple months - not getting signal in my leaving room
Message posted on 31 Aug 2026 10:21 PM
Re: WiFi disconnecting
@Aliona2 wrote:
not getting signal in my living room
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
