Discussion topic: WiFi disaster
Message posted on 01 Nov 2025 12:57 AM
WiFi disaster
At a complete loss .. Internet flashing orange and not working. But when running multiple service checks through the app it says nothing is wrong with WiFi or any surrounding areas. This happens multiple times and week and it lasts hours 🤦🏻♀️ I'm beyond fed up
Message posted on 01 Nov 2025 05:32 AM
Re: WiFi disaster
@Oaks
If it's still down you can use this link again to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
