Discussion topic: WiFi devices
This message was authored by: Tomsheringham
WiFi devices
Is there a limit to how many WiFi devices you can have connected to your Broadband
Re: WiFi devices
@Tomsheringham
Yes.  However there's a difference between the number of devices which a router can support (which is set by hardwar/software) and whether the total bandwidth arriving at the address is enough to supply each device with what it needs.
Current Sky routers (Broadband Hub, Max Hub and Gigafast+ Hub) are intended to handle a typical household of client devices.  Earlier models may be limited, but shouldn't still be in use anyway.
