Discussion topic: WiFi cutting out
This message was authored by: Perdie1
Message posted on 31 May 2026 06:50 PM
WiFi cutting out
My WiFi has been cutting out 6-7 times a day recently. Each time it is out it can range from 1-30 minutes. Often when I log onto the diagnostics it initially says 'there is an issue' but by the time I rerun the diagnostics it has come back on therefore offering no longterm solution.
Find out more
Message posted on 31 May 2026 08:09 PM
Re: WiFi cutting out
I suspect you'll need to call Sky and get them to review the Hub logs manually.
