Discussion topic: WiFi coverage poor around house.
Message posted on 21 Mar 2025 04:16 PM
New to Sky, have got 300m/**bleep** package but WiFi coverage weak away from router.
Message posted on 21 Mar 2025 04:53 PM
Re: WiFi coverage poor around house.
@Jukebox1 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 21 Mar 2025 06:33 PM
Thank you Chrisee, I have moved the router to a more prominent position and installed a TP-Link WiFi extender on the upstairs landing. Not perfect but can now get a signal in every room. Thanks for the quick reply.
