Discussion topic: WiFi connection
Message posted on 06 Oct 2026 02:10 PM
WiFi connection
Hi I have just checked my WiFi and can see it looks good but I work from home and I keep losing connection multiple times a day especially when on calls
Message posted on 06 Oct 2026 04:12 PM
Re: WiFi connection
@Georghiou84 do not confude he status of your broadband connection with the WIFi connection in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
