Discussion topic: WiFi connection
Message posted on 10 Jul 2026 08:25 AM
WiFi connection
From moving into my house in March we have struggled with the WiFi not connecting. My husband works from home and has to use the personal hotspot spot on his phone to work. The engineers placed the hub in a bedroom down stairs at the far side of the house and the living area is up the stairs. We often are unable to watch tv due to the connection however when I check the connection on the app it states it is fine. We can not carry on having reduced connection. What can be done.
Message posted on 10 Jul 2026 08:28 AM
Re: WiFi connection
@Rach10 wrote:From moving into my house in March we have struggled with the WiFi not connecting. My husband works from home and has to use the personal hotspot spot on his phone to work. The engineers placed the hub in a bedroom down stairs at the far side of the house and the living area is up the stairs. We often are unable to watch tv due to the connection however when I check the connection on the app it states it is fine. We can not carry on having reduced connection. What can be done.
Firstly, unplug the hub for 10 minutes and then reboot, hopefully a channel rescan will find a less congested wifi channel.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 10 Jul 2026 08:30 AM
Re: WiFi connection
Hello
thanks for the response we have gone through all trouble shooting I got an extender myself but it struggled to also get a connection. We have the highest package we can for our area.
Message posted on 10 Jul 2026 08:36 AM
Re: WiFi connection
@Rach10 wrote:Hello
Sadly speed to the router doesn't affect internal wifi for any supplier. Extenders should be placed roughly halfway between the main hub and wherever you need the wifi signal to reach, maybe check the placement first. Given your layout and needing to work from home I would give serious consideration to researching your own mesh system. What is your current extender?
Not a Sky employee
