2
This discussion topic has been answered Discussion topic: WiFi connection
This message was authored by: Gemma202
WiFi connection
Since moving from BT to sky working from home has got difficult: how can I boost connection?
Re: WiFi connection
@Gemma202
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Re: WiFi connection
@Gemma202
This message was authored by: Richiemck
Re: WiFi connection
All my other devices have a good connection yet my Amazon firestick doesn't when it is the closest device to my hub. Why is this and what can I do to resolve the issue
