Discussion topic: WiFi connection
Message posted on 04 Jun 2026 08:44 PM
WiFi connection
Our WiFi is not good on 3rd storey of house. Is there a way to improve this?
Message posted on 04 Jun 2026 09:23 PM
Re: WiFi connection
@Tracey195 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
