Discussion topic: WiFi connection
Message posted on 14 May 2026 08:50 PM
WiFi connection
The connection from WiFi is awful and has been for the past month - I've got a 3 story house and it's not strong enough or something is wrong - can this be fixed asap please?
Message posted on 14 May 2026 10:23 PM
Re: WiFi connection
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
