Discussion topic: WiFi connection
Message posted on 09 May 2026 11:45 PM
WiFi connection
Our Sky Max Hub has lost its internet connection.
The front of the hub is showing a slow flashing green light and has remained like this no matter what we have tried.
Rebooting devices and the Hub itself hasn't changed anything at all, and the Sky Service checker claims that there are no problems in the area, and even claims that the Hub is working fine and receiving internet! Clearly this is wrong because it will not connect to any device.
any help welcome!
Message posted on 10 May 2026 04:03 AM
Re: WiFi connection
@Telle21
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 11 Jun 2026 12:55 PM
Re: WiFi connection
Mines just doing the same thing this morning. Could be because of the rain, but it rains all the time and never had issues before. Done all the troubleshooting steps and now have to wait for an engineer to come out. My family and I rely on WiFi so much! Including watching the apps on Sky like Prime and YouTube! It's so annoying! Is yours still not working?
