1
This discussion topic has been answered Discussion topic: WiFi connection
This message was authored by: PINNOCKMARTIN78
WiFi connection
Can't connect PlayStation to Wi-Fi says Wi-Fi too weak can I get some assistance please?
Re: WiFi connection
@PINNOCKMARTIN78 if the WiFi signal is weak where the PS is even if you got it to connect it would be a miserable experience. To play games you nedd a strong steady data feed
Your options are
1) use  an Ethernet cable if praxtical its cheap and by far the best fir gaming
2) consider buying a powerline networking kit that uuses the mains wiring to carry the data
3) upgrade the wifi in that room either by paying for Sky's WiFi Max bundle and askinng for an extender or better buying your own whole home wifi system
Re: WiFi connection
Your options are
