Discussion topic: WiFi connection problem
This message was authored by ReadingSky This message was authored by: ReadingSky
We are having issues with pur sons games Console as the WiFi keeps dropping in and put of signal, is there a WiFi booster we can have to sort out this issue please.
Re: WiFi connection problem
@ReadingSky  Your duplicate posted you raised in the Sky Glass forum has been removed, you don't need to raise duplicate posts in other parts of the forum as it's not helpful.
You would need to call Sky about a booster.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
@ReadingSky
A booster likely wont solve WiFi dropping in and out. Is it happening for all devices or just the games console?
I am NOT a Sky Employee
