Discussion topic: WiFi connection poor in the same area
This message was authored by: Sonalgovindji
Message posted on 28 Mar 2026 07:58 AM
Living kitchen is open space yet issues when you are in the kitchen. Disconnects in the kitchen area
Find out more
Message posted on 28 Mar 2026 08:07 AM
Re: WiFi connection poor in the same area
@Sonalgovindji this is not unusual as WiFi signals are affected by the layout of the hime and what solid objects lie between the device and the hub. Anything made of metal like a fridge will block all direct signals a solid wall will often reduce signal strength by 50%. Requiring additional WiFi sources is very common but consider if moving the hub could help. Best position is off the floor on a surface well away from other electrical devices. If possible get it as high as you can
