Discussion topic: WiFi connection issue
Message posted on 02 Aug 2026 08:21 PM
WiFi is not connecting on any device.
Done all checks and resets but issue still continues
Message posted on 02 Aug 2026 09:39 PM
Re: WiFi connection issue
If the line test found no faults are the lights lit on your hub as usual, if so have you tried rebooting it at the mains ?
Message posted on 02 Aug 2026 10:13 PM
WiFi down cannot connect
Message posted on 02 Aug 2026 10:20 PM
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
