Discussion topic: WiFi connection dropping out
This message was authored by: Welbz
WiFi drops out and then reconnects constantly, two orange lights come on on the router box. Have turned off and reset but happens continuously, have tried the checker thing online but states everything is ok!
Re: WiFi connection dropping out
@Welbz
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
