Discussion topic: WiFi connecting to iPad
Message posted on 01 Apr 2024 04:33 PM
All my appliances connect to my WiFi very well except my iPads. We have 2 iPads and the connection on both of them is very slow.
Any suggestions?
Message posted on 02 Apr 2024 10:43 AM
Re: WiFi connecting to iPad
Can you tell us the iPad model?
Message posted on 02 Apr 2024 11:34 AM
It won't allow me to put in the model number. The iPads are 6th and 7th generation.
Thanks for your interest.
Message posted on 02 Apr 2024 11:58 AM
Those models do support dual band WiFi so the speed to them shouldnt be too bad.
What exactly is slow about them? It may just be that they are getting old now and it feels slow to use but thats down to the age of the device, not your broadband
Message posted on 17 Jul 2024 08:03 PM
All devices connect to wifi accept for an ipad. Have tried everthing suggested including resetting router and ipad. I try to enter the wifi password and it says incorrect password. Not sure what else to do
