Discussion topic: WiFi completely down.
Message posted on 25 Nov 2025 12:51 AM
This is ridiculous, ever since upgrading to sky stream this is the worst wifi I've ever had. I have to use my data in my own house 90% of the time.
Message posted on 25 Nov 2025 04:07 AM
Re: WiFi completely down.
@Leah200
When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach. Hopefully it'll be back up and running before 7am.
If it's not, use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
